John Deere 260 Eating Belt While Cutting Grass
   / John Deere 260 Eating Belt While Cutting Grass #1
Ron Williams
John Deere 260
All of the sudden the belt that runs the PTO to the deck started throwing the belt off. Bought a new one and it got destroyed within 5 minutes of cutting. Anyone know what's going on here?
   / John Deere 260 Eating Belt While Cutting Grass #2
If you have been sharpening blades a lot it could be they are out of balance. Had that issue last year with a CC 1045, a new set of blades solved the problem.
   / John Deere 260 Eating Belt While Cutting Grass #3
Make sure the belt routing is correct and check for bent or loose belt guides along the belt travel path.
I just installed new blades. The problem was there before I did that. I will investigate the routing. Thanks for the help!
   / John Deere 260 Eating Belt While Cutting Grass #5
Look closely at alignments. And with the belt off, check everything for bad bearings.
   / John Deere 260 Eating Belt While Cutting Grass #6
Be sure to use a genuine JD belt. They are made to a slightly different spec. than a general replacement that is available at a parts store. This is important for the correct operation.
Good luck,
Ken
   / John Deere 260 Eating Belt While Cutting Grass #7
check bearings on the pulleys and spindles and alighnment of tension pulleys, is your deck clean underneath and not hanging blades causing belt slippage_ let us know how you make out-------------
   / John Deere 260 Eating Belt While Cutting Grass #8
My dad just had the same problem with his 240. Turned out to be a bad bearing on one of the deck pullleys. The pulley had gotten hot and the metal deformed enough to cause the belt to wear very rapidly.
I think I have this figured out. I took advice on buying a JD belt instead of an after wrist and that helped. I also replaced the deck wheels since they appeared to be getting some play. Once I removed them they were wore out. Belt has not fallen off since. Thanks for the help!
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
CATERPILLAR 259D3 SKID STEER (A51242)
CATERPILLAR 259D3...
Terry 12ft Aluminum Jonboat (A50324)
Terry 12ft...
