John Deere 2520 Tach problem
   / John Deere 2520 Tach problem #1
ecr64
Brighton, Colorado
John Deere 2520
Hi all,
I have a 2007 JD 2520 that has 420 hrs on it that has been working perfectly for my light duty work on my 2.5 acres. Recently I am having a problem with the tach and wanted to know if anyone has experienced a similar problem and hopefully can recommend a fix. Every now and then, the tach needle on the display goes all the way to the max hard stop and I hear a high pitch "squeal". Throttling back does not affect (or correct) the situation. If I turn off, and restart the problem goes away for a while and then comes back after some time. Any thoughts? I haven't looked under the instrument cluster yet to check if something is loose, but that's my next step.
Thanks!
-E
   / John Deere 2520 Tach problem #2
I would start with the loose connections. Don't forget to check the ground wires. A loose ground can cause strange readings on instruments.
   / John Deere 2520 Tach problem #3
Loud squeal of a rotating shaft/instrument sounds like a dry bearing to me if mechanical. If electronic, I'd go with the loose connection Dave mentioned. If you loose ground on electronic circuits, no telling what they will do. A sloppy fitting connection could be doing just that as the shield on the cable/connector is usually part of the ground circuit.....I suppose.
   / John Deere 2520 Tach problem #4
Some tachs run off the alternator (usually stamped with a ("W") check the connections there also.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Mini Forks (A50322)
Mini Forks (A50322)
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Toro Mower (A50324)
Toro Mower (A50324)
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
