John Deere 2510,3020,4020 axle bearing race removal *********%#}%^
   / John Deere 2510,3020,4020 axle bearing race removal *********%#}%^ #1
joost123
Central, Texas
John Deere 2510 Restoration Poject - FFA
Hi, I have a 2510 and I'm replacing the rear axle bearings. I can't get the inside bearing races out of the axle housing. The races are set on top of a lip and I can't get a punch to punch them out. Does anybody know of a way to get then out? I tried a reverse gear puller and it isn't working. Any suggestions are greatly appreciated.
   / John Deere 2510,3020,4020 axle bearing race removal *********%#}%^ #2
Could you find or cut out a piece of metal and weld it to the race? I have seen replaceable valve seats removed by welding the old valve to the seat. A couple of taps on the stem and they pop right out
Pan
   / John Deere 2510,3020,4020 axle bearing race removal *********%#}%^ #3
Use a arc welder and weld a bead around the center of the old race. I use a 6011 1/8 or 5/32 rod. It will shrink the old race and it will fall out.
   / John Deere 2510,3020,4020 axle bearing race removal *********%#}%^ #4
RLstangs, i have used that method and it Works everytime.:thumbsup:
   / John Deere 2510,3020,4020 axle bearing race removal *********%#}%^ #5
I'll be the 3rd poster to state run a welding bead around the inside of the race.
   / John Deere 2510,3020,4020 axle bearing race removal *********%#}%^ #6
Also, after you get the race out, grind of some of the outside so that it will fit back in loosely. Then use this when driving the new race in, especially if the race has to be driven past flush.
Thanks for everybody's suggestions. I ended up cutting a piece of 1/2 inch steel rod 3 7/8" long and cuttin a notch on each end that fit in the slots and pressing the races out.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2019 Ford Fusion Sedan (A51694)
2019 Ford Fusion...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
