John deere 24t/14t differences
   / John deere 24t/14t differences
what prices are you seeing for operational 24T balers?
Bucktaker, I have seen 1100 to 2200 for operational, two with kickers for around 1800, and one for 7000! HOLY COW!!! It was pristine, but I'm on a cash budget, and it's not happening! LUTT
   / John deere 24t/14t differences #12
I'd paid $1500 for the 14T which was maybe a bit much considering some of the wear and tear but I was in a hurry and there weren't any other choices, but it worked well after some typical maintenance. I learned a lot, including why it's important to make sure the plunger stop is working properly. A spring broke, the knotter clutch slipped leaving the needles up, the plunger-driven hay hit the needles and folded one over... DOH! As a bonus I learned how to build a makeshift forge big enough to heat a needle and straighted it back out. I sold the 14T for $1350 at the end of the season when I got the 24T (I didn't want 2 balers to store over the winter). I paid $750 for my 24T and consider I got a fantastic deal on it.... and it came with a spare needle!
The 24T bale chamber was less rusty and deformed than the 14T, so it was a easy to justify trade-up - half the money and a baler in better shape. I had a few problems with it beyond regular maintenance - the main one was that the input shaft snapped off where it enters the gearbox after about 55 bales. Lucky for me a fellow who came to pick up hay when it happened repaired the input shaft for me overnight for free! The plunger head wrist pin was worn oval, as were a couple other bushings. The needle lift pushrod broke off where it pins to the knotter shaft output disk, which was an easy fix. I machined and made up a new wrist pin which quieted things down significantly. I replaced the other bushings and broken pickup tines and consider the baler ready for the next 100,000 bales. I suppose if I had to buy new parts and have someone else work on it, I'd have quite a bit of $$ into it, in which case buying a newer baler may have made sense, but since I enjoy working on things and have a fairly well equipped shop, I can "afford" to pick up some great deals.
One thing to point out, I suppose - I checked the 24T out pretty carefully before buying it. There was no indication the input shaft was suspect. bearings and seals were all tight and it all ran fine. After taking it apart I realized someone else had been in there before me. There was evidence of a gear crunching event. The drive bevel gears were replaced at that time, so I suspect something broke years ago which jammed the gears and stressed the shaft. It snapped off through the pin hole cross-drilled through the shaft just in front of the gearbox used to secures a collar that locates the bearing into the gearbox. Inspection of the break indicated a crack had been progressing for a long time. I suppose my point is that old (or any equipment for that matter) may fail in various ways, some of which are obviously impending due to regular wear, lack of maintenance, fatigue, operator malfunction/error/abuse or cascade effects from another failure.
Try to find the least worn and best maintained baler you can - wear is evident in wrist pins (plunger connecting rod), PTO shaft/clutch/u-joints), bale chamber plunger guides, and knotters. Also look for cracks in and around the bale chamber, and the amount of rust in general. I've heard stories of 24Ts passing 1,000,000 bales, so they're obviously well designed and maintainable.
Thanks Pete's, very useful for me! I will be doing my own work on the baler. I'm gonna screen shot this so I have it with me. Problem with them there all out of state. I've been talking to the sellers so hopefully one trip is all I will have to make! I'm a chief engineer on a large vessel and part time farmer. So working on one won't be a problem. I'm gonna try to find a manual for it when I get one. Also have a good machine shop down the road! Father n law bales with one years ago ! Don't really think I will get a kicker not unless it's on it. I have my two teenage girls, wife, father n law and I to gather up bales thanks LUTT
   / John deere 24t/14t differences #14
Thanks for the info
I will be selling my 24T along with the rest of my hay equipment this year. No Help and not enough time to keep it going.
Your welcome Bucktaker, if your baler is in good working condition, send me a pm if you have a idea what you want for it. LUTT
   / John deere 24t/14t differences #16
Here's a video I found about how to inspect a 14T: http://www.youtube.com/watch?v=2mxn4eyr5Mc
The same guy doing a similar video for a 24T, but it's not quite as informative in my opinion http://www.youtube.com/watch?v=Ffm7INY3CO4
I swear I'd come across a better how-to guide on what to look for (and look out for) when buying a used baler, but can't find it now.
Both the balers in the videos look fairly tired - I'd value them in the under $1000 range due to the amount of rust, indicating they were stored outside and not cleaned before storing each year. There was a recent thread on this forum from a guy trying to get his 24T knotters working. The photos of his knotters made me shudder - way too rusty for my liking and a lot of wear. Yes, everything can be repaired but it can get expensive fast if you have to buy new parts.
Most parts can be repaired/refurbished (or built) for very little cost with access to a welder, machine tools and time (new bushings, straghtening out bent things, welding broken things, building up worn things, etc.).
Let me know if you have any other questions, and I wish you the best in finding a good one!
Thanks a lot Pete's, you've been more than helpful. When I get the baler home, I will start a thread on going thru one. They are obviously a popular baler still. I will have pretty good support at my local JD dealer. Maybe you can help by the thread I start also. Thanks LUTT
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
