John Deere 2440 No PTO
   / John Deere 2440 No PTO
Yes the independent PTO clutch. The new clutch pack is in the mail. Ill update when the tractor is back together and working.
   / John Deere 2440 No PTO #12
Did you ever get your tractor running again? I assume so, my 1840 had a slipping PTO and it resulted in a new clutch pack, but the cause was a bracket on the internal hydraulic line to the PTO piston had chaffed and worn a large hole in it so PTO piston was not getting full pressure. New hydraulic line no longer has the bracket so unlikely to reoccur in my lifetime. Apparently this issue was common in the 1840/2440 machines.
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51242)
SET OF SKID STEER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
International 820 Platform (A50514)
International 820...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
