john deere 2320
/ john deere 2320 #1
vmt
john deere 2320
My 2320 is losing power under load dropping to a low rpm that would fluxuate between 1500-2500. If i would stop the mower it would recover but would act up again when i begin to drive. If i would have the mower on and not in drive, it seems to recover, It seems like it becomes starved for fuel under load. I checked all fluid levels and replaced the air filters....any suggestion welcomed!
/ john deere 2320 #2
Hi vmt and Welcome to TBN
How many hours since you changed your fuel filters?? I would think that is more of a concern than your air filters.
Greg
/ john deere 2320 #3
I had a very similar problem on my 4 year old 2320. I thought I was getting bad fuel and changed the fuel filter many times, until I found the real problem. Here is my post.
http://www.tractorbynet.com/forums/john-deere-owning-operating/224223-loosing-power-2320-a.html[/URL]
/ john deere 2320
I plan to change the fuel filter and check the fuel lines and tank outlet for any debris this weekend....i'll post how it goes....thanks for the help!
/ john deere 2320 #5
This happend to me. In my case it was the fuel filter. Easy change, and not much money either. :thumbsup:
/ john deere 2320 #6
Also happened to me, then it started cutting out altogether. Turned out to be a bad battery. Wasn't getting enough juice to the solenoid, so the fuel pump was not giving the engine enough juice (I'm not mechanical, so I probably phrased that improperly)
Anyway, thanks to advice of the fine folks here, I changed the battery. All is well.
/ john deere 2320
want to thank everyone for their input.....changed the fuel filter and she's running stronger than ever.....look's like it's back to work then!
/ john deere 2320 #8
And life is good!
/ john deere 2320 #9
That happened to me on my ex-2305. I was confused by the maintenance schedule, I forgot to change the filter when it was time.
VP
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2013 WESTERN STAR  4900 SB (A65643)
2013 WESTERN STAR...
2022 EZ-GO ELITE...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2018 ROCK SOLID CARGO EMERGENCY SHOWER TRAILER (A65643)
2018 ROCK SOLID...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
