john deere 2320
   / john deere 2320 #1
vmt
john deere 2320
My 2320 is losing power under load dropping to a low rpm that would fluxuate between 1500-2500. If i would stop the mower it would recover but would act up again when i begin to drive. If i would have the mower on and not in drive, it seems to recover, It seems like it becomes starved for fuel under load. I checked all fluid levels and replaced the air filters....any suggestion welcomed!
   / john deere 2320 #2
Hi vmt and Welcome to TBN
How many hours since you changed your fuel filters?? I would think that is more of a concern than your air filters.
Greg
   / john deere 2320 #3
I had a very similar problem on my 4 year old 2320. I thought I was getting bad fuel and changed the fuel filter many times, until I found the real problem. Here is my post.
http://www.tractorbynet.com/forums/john-deere-owning-operating/224223-loosing-power-2320-a.html[/URL]
   / john deere 2320
I plan to change the fuel filter and check the fuel lines and tank outlet for any debris this weekend....i'll post how it goes....thanks for the help!
   / john deere 2320 #5
This happend to me. In my case it was the fuel filter. Easy change, and not much money either. :thumbsup:
   / john deere 2320 #6
Also happened to me, then it started cutting out altogether. Turned out to be a bad battery. Wasn't getting enough juice to the solenoid, so the fuel pump was not giving the engine enough juice (I'm not mechanical, so I probably phrased that improperly)
Anyway, thanks to advice of the fine folks here, I changed the battery. All is well.
   / john deere 2320
want to thank everyone for their input.....changed the fuel filter and she's running stronger than ever.....look's like it's back to work then!
   / john deere 2320 #8
And life is good!
   / john deere 2320 #9
That happened to me on my ex-2305. I was confused by the maintenance schedule, I forgot to change the filter when it was time.
VP
2017 Chevrolet Silverado 2500HD 4x4 Crew Cab Reading Service Truck (A48081)
2017 Chevrolet...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
8ft. S/A Utility Trailer (A48082)
8ft. S/A Utility...
2002 53ft. Enclosed T/A Reefer Trailer (A48081)
2002 53ft...
2003 Komatsu PC200LC-7L Hydraulic Excavator (A49346)
2003 Komatsu...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A50505)
2019 PETERBILT 579...
