John Deere 2305 Starting and then Stopping Issues
   / John Deere 2305 Starting and then Stopping Issues #1
husting
Sammamish, WA
John Deere 2305
My JD 2305 has starting issue that is a bit different. When starting, the engine cranks over and starts but then dies out within a few seconds. This has been happening on and off for a couple years. Now I just can't get it started. I used a volt checker and I get 12.8 volts on the battery so it seems to be working, but I haven't replaced it.
What could be causing it to cut out?
Patrick
   / John Deere 2305 Starting and then Stopping Issues #2
Does it still crank? If so, try jumping the battery. Your current battery may be drawing down.
If it starts, and continues running...probably time for a new battery.
If it starts but doesn't continue to run, I'd look at the fuel filter as a potential cause.
It does start, revs for about 1 second and then never catches and dies out. The fuel filter is clean, well, looks good to me anyway. :)
Any other ideas? I've seen other post the same issue, but never see a response on what the issue was to fix it.
Guess I will have to call service.
Patrick
   / John Deere 2305 Starting and then Stopping Issues #4
Patrick
Do your headlights work, by chance?
Since I don't own a 2305, you'll have to check your manual...especially for any fuses or relays that protect fuel delivery circuits. Your manual should have a trouble shooting section, so I suggest you start there.
Safety switches should prevent cranking, so It's probably not a safety switch
Yep, you may have to contact the dealer...
Yes, headlights on.
I'm digging out the manual now and going to go try and figure it out. :eek:) Thanks for the advice.
Patrick
   / John Deere 2305 Starting and then Stopping Issues #6
Could be a problem with the fuel shutoff solenoid. I believe there is a separate circut to energize it for starting and running.
   / John Deere 2305 Starting and then Stopping Issues #7
Maybe this will help.
   / John Deere 2305 Starting and then Stopping Issues #8
Have you checked your fuel lines for obstruction? Here in N. Florida algae grows in the fuel and will restrict the flow. I've worked on tractors with the symptoms you describe and have found that to be the case.
   / John Deere 2305 Starting and then Stopping Issues #9
I have the same issue. I had a mobile mechanic come out and he diagnosed it to be a bad fuel shut off solinoid. So I ordered one and it does the same thing. When it is removed from the engine, it runs like new. Something is setting off that solinoid right after it starts. If I hold the ignition switch key to start, it will run for a second or two longer. I believe my problem is the key switch. I hope this might help you.
Bob
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Pull Type ATV Sprayer (A59814)
Pull Type ATV...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
