John Deere 2305 gas tank removal
   / John Deere 2305 gas tank removal #1
shawnharmon
Havre
I need to remove the gas tank because there is something in it the keeps plugging the fuel line, To big to flow thru the fuel line, I have used low pressure to blow it back into the tank. It just keeps coming back. I will need to remove the side covers and control panel and lower shroud. I am just not sure how to get those all the way off.
Thanks Shawn
   / John Deere 2305 gas tank removal #2
I think the problem is that they put a gas tank on there. ;)
Sorry I can't help further.
   / John Deere 2305 gas tank removal #3
Have you checked the interior of the tank for rust? If it's rust that's clogging it, you would probably need a new tank. If its just an object that fell in your tank while filling, you could probably use a flashlight and a flexible claw pick-up tool to remove it. That way you can leave the tank where it is.
Good luck,
-Dominic
   / John Deere 2305 gas tank removal #4
If it is rusted there are companies that line tanks and guarantee them for a lot less than a new tank. I had a truck I did it on and it was like a new tank.
Any idea what's in there?
I will check that out first, did not think of using a claw, do not think it is rust, only 105 hours on the tractor I will post when I find out.
Thanks Shawn
Chuckles, go figure, a gas tank on a tractor:laughing: That way you worded it made me smile Mike
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 101"...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
