John Deere 2305 gas tank removal
   / John Deere 2305 gas tank removal #1
shawnharmon
Havre
I need to remove the gas tank because there is something in it the keeps plugging the fuel line, To big to flow thru the fuel line, I have used low pressure to blow it back into the tank. It just keeps coming back. I will need to remove the side covers and control panel and lower shroud. I am just not sure how to get those all the way off.
Thanks Shawn
   / John Deere 2305 gas tank removal #2
I think the problem is that they put a gas tank on there. ;)
Sorry I can't help further.
   / John Deere 2305 gas tank removal #3
Have you checked the interior of the tank for rust? If it's rust that's clogging it, you would probably need a new tank. If its just an object that fell in your tank while filling, you could probably use a flashlight and a flexible claw pick-up tool to remove it. That way you can leave the tank where it is.
Good luck,
-Dominic
   / John Deere 2305 gas tank removal #4
If it is rusted there are companies that line tanks and guarantee them for a lot less than a new tank. I had a truck I did it on and it was like a new tank.
Any idea what's in there?
I will check that out first, did not think of using a claw, do not think it is rust, only 105 hours on the tractor I will post when I find out.
Thanks Shawn
Chuckles, go figure, a gas tank on a tractor:laughing: That way you worded it made me smile Mike
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
JOHN DEERE LOT NUMBER 122 (A53084)
JOHN DEERE LOT...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
