John deere 2240 3pt
   / John deere 2240 3pt #1
willy44
MI
John Deere 2240
Hello everyone, I was using my 2240 with a 6ft blade on the back to level out some gravel and I lifted the blade up and when I went to put it back down it wouldn't go down. I went out to see if it would work today and when I started it up the blade went all the way up and down about 4 times then when I moved the blade up it wouldnt go down again. However when I shut the tractor off I can put the blade down. Any help would be greatly appreciated.
I think I figured it out, when I got on and off the tractor I managed to kick the rate of drop valve under the seat. I turned it and the 3 point works again.
   / John deere 2240 3pt #3
You're not the 1st person & probably won't be the last to close the R-O-D screw on a JD utility of that era. I glad you got it sorted out.Jim
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2008 DODGE RAM TRUCK (A51243)
2008 DODGE RAM...
2014 Mack CXU613 Semi (A50514)
2014 Mack CXU613...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
