John Deere 2210 with Curtis Hard Sided cab
   / John Deere 2210 with Curtis Hard Sided cab #11
That is a very nice cab, I think I will be looking for one before next winter. Nice little Cub also, very similar to the one I had, It flew well.. JohnJ
   / John Deere 2210 with Curtis Hard Sided cab #12
Wow, nice cab and tractor. Can the cab be removed and if so how long does it take?
I have a Kubota L3430 and am considering the Curtis Soft Cab to use in the winter. I need it off in the summer to get under trees and in buildings. I may build a shelter type cab out of PVC pipe and plexiglass.
ksmmoto
   / John Deere 2210 with Curtis Hard Sided cab #13
Collin, do you have any pictures of exactly how the heater hoses connect to the motor ? Are there connecters that take advantage of access points to the water jacket ? /forums/images/graemlins/tongue.gif
   / John Deere 2210 with Curtis Hard Sided cab #14
Forget the heater, where's the AC unit!!
btw - very nice /forums/images/graemlins/cool.gif
Can you get an a/c unit for it? that you know of cuase that would be nice.
The doors come off in a matter of minutes and the windshield and rear window do as well. If the trees and buildings clear your ROPS then you should be good my cab is just a 1/2 inch or so shorter than the ROPS. Except I have the work lights up ontop and the strobe. I would suggest if you can to get the cab with the hard sides, becuase the soft sided one dosn't have slideable windows and i use them a lot even when its snowing out becuase it gets kind of stuffy in there and opening the front window lets the water in from the snow hitting the warm windshield.
Here are a few pictures of how the hoses come out of the cab and into the engine compartment and then a couple of how they connect into the system i labeled them heat tube 1 and 2.
heres the system connection
and another for the other hose
   / John Deere 2210 with Curtis Hard Sided cab #20
Thanks ctc1111. I see that the inflow to the heater comes off that upper connection intergrated with the temp gage sender and the return involves splicing into the lower radiator hose with the shut-off on the return side. /forums/images/graemlins/laugh.gif
Is it worth it to insulate the inflow hose or does the heater supply plenty of heat ?
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
HUSQVARNA RIDING...
2007 CHEVROLET KODIAK C4500 (A58214)
2007 CHEVROLET...
