Traction John Deere 2210 - question on tires
   / John Deere 2210 - question on tires #1
aolsonwi
John Deere 2210
I have had my 2210 for roughly 10 years now, and I love it. Starting last fall before winter, I noticed my tractor has having problems going uphill when the grass was wet from rain. The rear tires would end up spinning, which rarely happened over the past 10 years. Over the winter, I noticed this also since I used my 2210 to plow my driveway. I would have a hard time getting up my driveway which is sloped. I ended up having to put chains on my rear tires, which again - I have rarely had to do.
This weekend I was hauling some garden waste since we finally got a glimpse of spring. My tires once again started to spin going up a hill. I had to back down all the way, and floor the accelerator.
Question - is this due to tire wear? the tire treads look OK. I rarely drive on concrete, only in the winter to plow the driveway. I am primarily all over my backyard, mowing, hauling, etc.
Could this be a tire pressure issue? Or could this be something else? All input appreciated.
Alan
   / John Deere 2210 - question on tires #2
You can try to lower pressure, if you are still unsatisfied buy new tires and might as well go with a more aggressive tire. You said the tread still looks ok, 50% tread wear looks ok but in fact no where near as effective in the dirt and grass, also rubber might loose some of its nice soft compound in time and even start to dry rot. If someone wanted to go threw the effort they might fill them with windshield washer fluid to add weight for more traction. Washer fluid won't freeze in the winter.
   / John Deere 2210 - question on tires #4
Rubber can become a lot harder, and the tread lugs slicker with age and use. Tires that once bit in and went, now slip. If the tires look good still, you might want to consider adding Rim Guard or new tires with a bit more aggressive tread.
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
2014 Dodge Charger Passenger Car (A55853)
2014 Dodge Charger...
2013 John Deere 824K Wheel Loader (A57024)
2013 John Deere...
2002 CATERPILALR D8R HI-TRACK CRAWLER DOZER (A52707)
2002 CATERPILALR...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
