John Deere 2155 won稚 start
   / John Deere 2155 won稚 start #1
Nole0001
TN
John Deere 2155
Hi I have been working on a John Deere 2155 that won稚 start I replaced the Solenoid on the starter it still won稚 start now I have no power to my ignition switch help thank you
   / John Deere 2155 won稚 start #2
First check ground at chaccic....then....fuses....circitbreaker....neutral startswitch
   / John Deere 2155 won稚 start #3
Welcome to TBN
If not already performed I will recommend relocating negative battery cable connection from battery box to starter mounting bolt or engine block. I wonder if your tractor has had a JD starter relay kit(see photo below) added? Neutral start switches have a history of loosing some movement of ball by shift rail. One can remove a sealing washer or 2 on switch to sometimes gain better connections on switch. BTW switch is located on top of rockshaft housing.
   / John Deere 2155 won稚 start #4
I also have a jd 2155 that will not start the battery is good but when I turn on the switch no lights come on the the dash and won’t start. Can anyone give me any help
   / John Deere 2155 won稚 start #5
Have you checked the fuses? (Not just blown but 'seated' properly)
The same thing goes for all of the wiring/cables... the battery posts may look fine but the cables themselves may be corroded/brittle just under the insulation. Engine vibration is a real 'bugbear' and can loosen many connections over time.
   / John Deere 2155 won稚 start #6
I’ve checked all the fuses I will check the wiring tomorrow thanks
   / John Deere 2155 won稚 start #7
Saying "battery is good".. and does that mean the battery has been load tested?
If not load tested, and more than 5 yrs old, I'd be thinking it needs replacing.
UNUSED JCT 84" HYD 4N1 BUCKET (A57193)
UNUSED JCT 84" HYD...
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
Brown BDH-750 (A56469)
2022 John Deere 6120M (A53317)
2022 John Deere...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
