John Deere 2155 Battery size
   / John Deere 2155 Battery size #1
JPAGE77
Douglasville ,ga
John Deere 2155
I have a JD 2155 that i just got the alternator rebuilt on. My brother in law took out the old bad batteries and now they have dissappeared.:confused2: Does any one know the size/group number that fits this tractor????? I have the two battery set up. Thanks
   / John Deere 2155 Battery size #2
The Deere dealer has two different sets in stock. Both sets have the same CCA rating but one model has a higher amp hour capacity.
Purchase an extra "ground " cable and run it from a battery (-) to a mounting post on the starter. Also connect and use the factory's 2nd rate connection to the sheet metal.
I was shocked at how much faster the engine cranked with the same batteries and starter with the proper (-) chassis return connection.
   / John Deere 2155 Battery size #3
This is what's listed for a 2155 with dual batteries. These are 55AH batteries . 88 AH battery is shown with only one battery.
   / John Deere 2155 Battery size #4
The battery compartment could the same size on the three cylinder 2155 and four cylinder 1640? The four cylinder specs larger batteries which will be welcome even on a three cylinder on a cold day, if they fit.
AL203837 Wet Charged Battery 12V, 66AH, 300A
   / John Deere 2155 Battery size #5
This disclaimer comes up when AL203837 is inserted in a JD parts search on JD's website. b&d isn't a dry charged battery supposed to have a better self life than a wet charged battery?
Thanks Guys!!! that is what i needed!!
   / John Deere 2155 Battery size #7
Wet is fine if used in a month or two . Or if it's trickle charged monthly. True the safest and freshest battery is the "dry charged " unit.
2025 CFG Industrial QK16R (A50123)
2025 CFG...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
1999 John Deere 4300 (A50123)
1999 John Deere...
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
