Years ago I had a David Brown that acted similar. There were two spool valves in the rear end housing to the right of the drivers seat. You could access them by removing a cover and unscrewing the top caps off each being careful to not let the cover or spring under it pop up and then down into the rear end housing (yah that's how I know that one).:ashamed: Once the cover was off and the spring recovered you could slip the spool up out of its seat and flush off the bit if grit that had got stuck between the spool and the close tolerance hole it fits into. This bit of grit or metal was what was catching the spool in the part open position and causing the problem. Something 1/10,000 inch was all it took and could be a bit of dirt that washed down the shift lever past a worn boot and into the rear end that served as the hydraulic reservoir. Maybe something along that line is your trouble?
