John Deere 2140 Blowing White Smoke
   / John Deere 2140 Blowing White Smoke #1
FlAr2010
John Deere 2140
Let me just start this post by saying that I am as far from a mechanic as you can get. Also...I am new to this site so if this is the wrong place to post repair type questions let me know and I can move it to the correct place. With that being said...I have a John Deere 2140 that is blowing white smoke from the exhaust and I have no idea where to start to find the problem. I started the tractor this morning to move a bale of hay and the smoke was there. I have not ever noticed the smoke before. I have read that a tractor can smoke on a cold cold morning but the smoking did not cease after the tractor warmed up. It only seemed to get worse. While moving the hay...the tractor seemed to sputter and miss when I increased the throttle. Any responses would be greatly appreciated. Thanks.
   / John Deere 2140 Blowing White Smoke #2
Sounds like you have a cylinder thats running cold, possible injector/fuel nozzle causing the problem or a blown head gasket. Check the oil for signs of coolant, gray foam on the dipstick or on the oil fill cap. Check the coolant level an see if is low. Becareful if you try this, you should have 2 people, if you can get at the exhaust manifold, have someone start the tractor when it's cold, then feel the exhaust manifold at each cylinder and see if one is running colder then the rest. The cold cylinder would be where I'd start at.
   / John Deere 2140 Blowing White Smoke #3
Did happen to catch a whiff of it and can describe the smell ?
   / John Deere 2140 Blowing White Smoke #4
I'd start simple. Fuel filter? Jelled fuel? Moisture?
   / John Deere 2140 Blowing White Smoke #5
Gelled fuel. Don;t know where you are at. Change filters and treat your fuel. You may have to throw some red power service at it.
Thanks everyone for the replies. I am in central Arkansas. It has been cold lately...right at freezing...maybe a little lower. I don't know how cold it has to be in order for fuel to gel??? I did check the oil today...no gray foam on the dipstick (however the oil was very black and in need of change) but I did not check the oil cap...will do that tomorrow. However the coolant level was low...added half a gallon. The smoke had a stalt burn smell to it...not sure how to describe it other than that. Will do the cold cylinder test tomorrow.
Assuming this is a cylinder or head gasket problem...and my mechanic expertise being minimal...is this a problem I could work myself through using a repair manual. And approx how much am i going to be out on this deal...doing it myself or taking it to a john deere dealer?
Thanks for all your help.
   / John Deere 2140 Blowing White Smoke #7
stalt ?, did you mean salt ?
White smoke means one of two things, coolant or fuel.
Coolant would have a slightly sweet smell, fuel would smell like fuel, heavy oil.
   / John Deere 2140 Blowing White Smoke #8
bad injector
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
1975 Miller 40' Flat Bed Semi Trailer (A50121)
1975 Miller 40'...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2015 PETERBILT 389 (A52472)
2015 PETERBILT 389...
