John Deere 2120 from 1971 repair book
   / John Deere 2120 from 1971 repair book #1
Bejenaru
La Norville
John deere 2120
Hello,
Can someone help me with a service repair book for this model of tractor JD 2120 from '71 or with the explanation of how to change the back shaft from the wheel?
Thanks!
   / John Deere 2120 from 1971 repair book #2
Which shaft are trying to change(pto or rear axle or load control)???
Rear axle, it starting to leak.
   / John Deere 2120 from 1971 repair book #4
Final drive housing must be removed from tractor to replace inner seal.
Thank you very much Jim.
Do you have also the parts name?
Thanks!
   / John Deere 2120 from 1971 repair book #7
If your tractor has regular final drive these are the parts to repair leaking rear axle.
T21419 Gasket
AL39391 Seal
thanks for the info Jim.
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
