John Deere 212 - Starter or battery
   / John Deere 212 - Starter or battery #1
joe z
Woodsboro, MD
John Deere 212
I have a John Deere 212 from the mid-eighties. I bought it used. The battery has a sticker on it that says it is two years old (3/11). I been having issues with it holding a charge and thought I may have something draining it when the tractor is off like a short, or I'm having issues with the charging system. The ammeter sometimes shows it is charging, and other times looks like it s discharging while the tractor is running. Yesterday, the tractor wouldn't start, it just clicked. No problem, I thought, I'll just take the battery out and charge it again. However, now the starter just make a whirring noise, but doesn't engage. Is it likely the starter or the battery or something else? I priced the starter at a Deere dealer, and the battery would be the cheaper thing to try first, but any help or advice would be greatly appreciated.
   / John Deere 212 - Starter or battery #3
I spent the price of a battery on a load tester, it has saved me many times that price over the years just with a car, truck , tractor and lawn mower. I used to sell auto parts and many good batterys has been replaced.
Have a volt meter, not a load tester.
   / John Deere 212 - Starter or battery #5
OK how many volts does battery have before & after attempting to start engine? Low voltage or dirty starter gear engagement mechanism can cause starter to spin but gear not engage flywheel gear.
   / John Deere 212 - Starter or battery #6
hook volt meter to battery, read voltage, try to start unit and watch voltage, if drops to 9 volts or less, replace battery.
You could also remove battery and take to a shop and have it load tested. Also need to check cables and connections to ground too.
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
