John Deere 212 - Starter or battery
   / John Deere 212 - Starter or battery #1
joe z
Woodsboro, MD
John Deere 212
I have a John Deere 212 from the mid-eighties. I bought it used. The battery has a sticker on it that says it is two years old (3/11). I been having issues with it holding a charge and thought I may have something draining it when the tractor is off like a short, or I'm having issues with the charging system. The ammeter sometimes shows it is charging, and other times looks like it s discharging while the tractor is running. Yesterday, the tractor wouldn't start, it just clicked. No problem, I thought, I'll just take the battery out and charge it again. However, now the starter just make a whirring noise, but doesn't engage. Is it likely the starter or the battery or something else? I priced the starter at a Deere dealer, and the battery would be the cheaper thing to try first, but any help or advice would be greatly appreciated.
   / John Deere 212 - Starter or battery #3
I spent the price of a battery on a load tester, it has saved me many times that price over the years just with a car, truck , tractor and lawn mower. I used to sell auto parts and many good batterys has been replaced.
Have a volt meter, not a load tester.
   / John Deere 212 - Starter or battery #5
OK how many volts does battery have before & after attempting to start engine? Low voltage or dirty starter gear engagement mechanism can cause starter to spin but gear not engage flywheel gear.
   / John Deere 212 - Starter or battery #6
hook volt meter to battery, read voltage, try to start unit and watch voltage, if drops to 9 volts or less, replace battery.
You could also remove battery and take to a shop and have it load tested. Also need to check cables and connections to ground too.
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
