Feb 28, 2011 / John Deere 212 drive belt #1 G gitumjo New member Joined Feb 28, 2011 Messages 4 Tractor John Deere 212 The drive belt at times will come off when you hit a bump. Its a new belt and still does it.
Mar 1, 2011 / John Deere 212 drive belt #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,693 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) The front drive belt from the engine to the shiv pulley, or the rear drive belt from the shiv pulley to the tranny?
Mar 1, 2011 / John Deere 212 drive belt Thread Starter #3 OP G gitumjo New member Joined Feb 28, 2011 Messages 4 Tractor John Deere 212 Its the front drive belt
Mar 1, 2011 / John Deere 212 drive belt #4 O oldnslo Super Member Joined Jan 20, 2010 Messages 8,849 Location Northern, IL Tractor Branson 2400H, JD X540 If your 212 is like my 112 there should be a couple of guides around the front pulley to prevent the climbing out of the groove. On mine they look like studs/bolts that screw into the block. Roy
