John Deere 2048 Sabre bad hydro trans?
   / John Deere 2048 Sabre bad hydro trans? #1
billbled
hi,
I've got a JD Sabre 2048 lawn tractor, with a bad hydrostatic trans. Is there a way to get this repaired/rebuilt for $300 to $400 or is that a pipe dream? I've checked the oil level and it's in spec - it's at 73mm down from the neck. I don't see where there are much other things to check - short of going into the box.
Anybody got ideas?
Thanks,
Bill
   / John Deere 2048 Sabre bad hydro trans? #2
If it a Tuff Torq transaxle, they sell rebuild kits. Also they recommend synthetic 5w-50 for most of the newer ones.
Once you determine the type, you can do a search on some "other" lawn mower sites and get lots of good information on rebuilding or replacing it.
Good Luck
   / John Deere 2048 Sabre bad hydro trans? #3
Hi,
Thanks for the heads up. I've found the ID tag on the transaxle - it says "K65-SBR.....S/N: 011578.......JDHW P/N: AM126957"
Also, I've now pulled the hubs off and the woodruf keys do not appear to be sheared. So I'm thinking it really is inside the transaxle.
Big pain to rebuild?
More news....as troubleshooting continues.
I pulled the input pulley off - the one that the drive belt wraps around - and the splines inside of it are gone. The splines on the trans look salvagable - so hopefully just a pulley will do it. Going tomorrow to get one.
Thanks for all the feedback.
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
