John Deere 2040 with Open Center valve on FEL
   / John Deere 2040 with Open Center valve on FEL #11
We can't solve Jimmy_G's tractors hyd problem until he reveals whether his tractors serial # is below or above 266,750
   / John Deere 2040 with Open Center valve on FEL #12
Seems alot of people don't understand a CC system.
It's alot like compressed air in your shop if you have a shop plumbed and several drops.
Anywhere in the system you can hook in a tool and have pressure. Because the air cannot escape the system....pressure builds....compressor quits pumping until you start using air.
Now have an open line....representing an open center system. It will never build pressure...compressor will run 24/7 and never build pressure.
This is why the OP's 3ph don't work. If it's closed center and his valve is open center.....it will NEVER build pressure until he deadheads a loader function like curl back and keep holding.
But until the OP ever reports back with a serial #, we just don't know
   / John Deere 2040 with Open Center valve on FEL #13
LD1
I think that was a very good simplified explanation for operation of closed-center hyd system. In the past I've compared CC hyd system operation to shallow water well pump/pressure tank system. Water pump builds pressure in tank then switch cuts pump off until pressure in tank drops then switch turns pump on. Large water leak causes pump to operate continuously.
I was employed by JD dealer from '66-'87 which was a large portion of the ''main hey day of CC hyd's'' & served as a dealer service manager for the last 13 yrs helping technicians solve CC hyd system problems.
IMHO the main key to solving CC hyd problems is performing very good diagnostic procedures.
   / John Deere 2040 with Open Center valve on FEL #14
That is the main key in solving any hydraulic problem whether it's open center or closed
   / John Deere 2040 with Open Center valve on FEL #15
I like both, the shop air system and well pump system, as analogies for the closed center hydraulic system. The swash plate and pistons are at the heart of the operation.
Thinking back to the late sixties/early seventies, Cessna Hydraulics in Hutchinson KS was building a piston pump developed by Algear (Oilgear?), a German company IIRC. I didn't at the time realize why all the excitement for this "new pump" but I'm now wondering if it was a forerunner to modern day hydrostats. I believe they eventually abandoned the project as they found the cost to build excessive due to the tight tolerances required. Anyone know the history?
Edit: Perhaps the hydrostatic drive was first used by the Germans in the Panzers?
https://tanks-encyclopedia.com/ww2/****-germany/panzer-iv-mit-hydrostatischem-antrieb/
   / John Deere 2040 with Open Center valve on FEL #16
JD closed center hyd's on tractors built from '61-'92 do not utilize a swash plate. Those systems utilize a stroke control valve to control pumping. When stand-by pressure(2250 psi) is achieved stroke control valve opens diverting pressure oil to crankcase of main hyd pump pushing pistons away from rotating shaft which causes pumping to cease. When pressure in system drops then springs push pistons down against rotating shaft then pumping commences.
   / John Deere 2040 with Open Center valve on FEL #17
I may be prejudice but I think good diagnostics is more important diagnosing closed center hyd's because JD CC hyd's is understood by a smaller percentage of people
   / John Deere 2040 with Open Center valve on FEL #18
You may be correct. But it seems hydraulics in general are understood by by a very small percentage of people.
   / John Deere 2040 with Open Center valve on FEL #19
For me....closed center is easy. Being able to simply tee everything....
You either have oil pressure or you don't. Sure there are wildcard cases like this where one uses a wrong valve.
But in open center stuff.....I thing there is a very very small percent of people that truly understand PB and how it functions.
I think everyone's natural instinct is to plumb as if it was CC (or like they would shop air). Just tap a pressure like somewhere and install valve. Hard to get people to understand and grasp the concept of PB
   / John Deere 2040 with Open Center valve on FEL #20
That's interesting! Any online animations showing how this works?
20ft. Deer Gate (A53424)
20ft. Deer Gate...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
Deere 304K (A53317)
Deere 304K (A53317)
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
