JOhn Deere 2030 problem
   / JOhn Deere 2030 problem #1
bullrun
My JD 2030 starting stutting down under load. I thought it was a dirty fuel filter, so I changed it. After bleeding the air, it still will start, but a few secondss (sometimes a minute) and die. I have pulled it on the road to be sure that the air is all gone. I have also blown out the fuel lines - good flow. What do I do next?
   / JOhn Deere 2030 problem #2
It sounds like you might have a bad injection pump. A sealing ring in these pumps sometimes goes bad and causes the fuel return line to clog. Too much case pressure builds up in the housing and causes it to shut down. To check it out, there is a small cover on the side of the pump which is held by 2 screws. Remove that cover and see if there is any black ground up rubber that resembles coffee grounds. Put a bucket under the pump before you do since some fuel will leak out. While the cover is off, try starting the tractor, it should stay running since the return fuel can now leak out into the bucket. The only option if this happens is to removethe pump and send it to a fuel shop to be rebuilt or buy another pump. Rebuilding is usually alot cheaper if you can wait a few days to get it back.
John Deere 893 Corn Head (A50514)
John Deere 893...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
19200 (A50324)
19200 (A50324)
2006 International 9400i (A52128)
2006 International...
