John Deere 2025r pto problem
/ John Deere 2025r pto problem #1
KubotaSam
Maine
Kubota B2410, Kubota B7100Dt, Kubota B7100HST
My step son borrowed a friends 2016 JD 2025r to do some bush hogging around his house. Everything was fine on Saturday. Today when he went out to cut some more the pto was acting up. As I understand it it is an electrical switch that engages it. Sometimes it will operate for 5 to 10 seconds sometimes not at all. I told him to look for wires pulled off the underneath but it has no obvious hanging wires. Anyone have any ides of where to start looking?
/ John Deere 2025r pto problem #2
If it were mine I would take the switch off, check to make sure that its working correctly and start following the wires! Probably goes into a harness soon after the switch, you should still be able to follow them though. Might get lucky and just have a problem with the switch.
I will pass along your hint.
Can anyone describe how the pto actually works? I assume that it is an electric/hydraulic circuit that operates a clutch. However that is just a guess and I would appreciate any other info and a description of how it works.
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
Winco 12T Fertilizer Tender Box (A66408)
Winco 12T...
KBH Tender Trailer (A63689)
KBH Tender Trailer...
John Deere 490E Excavator (A62679)
John Deere 490E...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
