John Deere 2010 Gas tractor
   / John Deere 2010 Gas tractor #1
Pieter78
Des Moines
John Deere 2010
Hello :laughing:
I am new to this forum. I have a John Deere 2010 gasoline tractor. When I start it it will start but as soon as you let go of the key it will die. I just replaced the ignition switch. I need help?:confused:
Thanks Pieter
   / John Deere 2010 Gas tractor #2
My GUESS is that the coil gets 12 volts when starting and then a lower voltage for running for less wear on the points.
Check for voltage at the coil Positive terminal with the key "ON"
   / John Deere 2010 Gas tractor #3
I've had this happen a few times due to the ballast resistor going bad.
Thanks for the advice.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
Probst Metal Cart (A50774)
Probst Metal Cart...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
2017 Ford F-150 XL (A50120)
2017 Ford F-150 XL...
