John Deere 2010 Gas tractor
   / John Deere 2010 Gas tractor #1
Pieter78
Bronze Member
Des Moines
John Deere 2010
Hello :laughing:
I am new to this forum. I have a John Deere 2010 gasoline tractor. When I start it it will start but as soon as you let go of the key it will die. I just replaced the ignition switch. I need help?:confused:
Thanks Pieter
   / John Deere 2010 Gas tractor #2
My GUESS is that the coil gets 12 volts when starting and then a lower voltage for running for less wear on the points.
Check for voltage at the coil Positive terminal with the key "ON"
   / John Deere 2010 Gas tractor #3
I've had this happen a few times due to the ballast resistor going bad.
Thanks for the advice.
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
