John Deere 2010 Back hoe
/ John Deere 2010 Back hoe #1
farmerjon0020
Ny, Ny
John Deere 2010
My John Deere 2010 Back hoe has air coming out of the air intake. I know it needs to have the injectors rebuilt, but as far as the air coming out the intake is it a form of blow-by or something else?
/ John Deere 2010 Back hoe #2
Are you sure about that? I've seen where it looked like aircoming out, but it wasn't.
Is the motor running?
I've seen this with 2 strokes that one way or another ran backwards. Never seen or heard of it with a 4 stroke engine that was running.
The only way can think of it happening is a stuck intake valve, maybe. I would think though that any air coming back through that valve though would get sucked through the other cylinders.
Yeah I don't understand it either but when you give it a hit of ether when the engines running to clear it up, it sprays about 50% of it back at ya
/ John Deere 2010 Back hoe #4
First off ether shouldn't be used a an engine with "glow plugs". Sounds as if an intake valve(s) isn't seating correctly allowing compression into air intake. A compression test will identify if this is true.
Glow plugs don't work :mad: okay I'll give a compression test a try
/ John Deere 2010 Back hoe #6
Using ether is one of the 1st clues. Blown head gaskets, cracked pistons, broken rings, crushed ring grooves, bent rods, damaged rod bearings are just a start. Valves and seats could also be damaged by the pressure spikes which can exceed 3 to 4 times full load combustion chamber pressures. Use a block heater and/or glow plugs but leave that stupid ether alone.
Glow plug don't light other wise i would, and its parked out in the middle of a field most of the time don't have a extension cord that long to use the block heater, I know the ether is bad for it sadly its the only way to get it to fire up or yull sit there all day cranking the darn thing. I let it sit for a few secs before i crank it up after the shot of ether so it doesn't bang around that bad
/ John Deere 2010 Back hoe #8
ether is ok on many deeres as they come with ether start systems. My 1520 is very tiered but a shot of ether and she cranks right up no matter the temp. I have new pistons/ liners but as long as it will start im in no hurry to rebuild .
/ John Deere 2010 Back hoe #9
Brimstone10x
Utilizing a factory ether starting aid is "much better" way of using ether than spraying in air intake. Ether starting aid has a small orifice to help limit the amount of ether that engine is exposed to rather than an overdose.
/ John Deere 2010 Back hoe #10
The factory ether assist is for emergency use for when the block heater either doesn't have enough time to pre-warm the engine. Or if caught in the middle of nowhere without power. If there is a choice to use ether or a block heater. The operator is foolish to use ether. A pre-warmed engine suffers less cold start wear too.
/ John Deere 2010 Back hoe #11
buickanddeere
Block heaters weren't offered on a 2010 because there's no "hole" to install one in the block. 2010 would require a "tank" heater.
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2019 MACK PINNACLE (A67714)
2019 MACK PINNACLE...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2022 John Deere 6175M (A64911)
2022 John Deere...
CAT 345CL Sprockets (A68134)
CAT 345CL...
(2) Bean Royal Sprayers (A64912)
(2) Bean Royal...
