John Deere 185 running issues
   / John Deere 185 running issues #11
You should be aware that this engine has a "automatic compression release" so you have to make sure that the exhaust valve is closed after top dead center.
I made sure engine was at TDC and set the valves correctly. This did not correct my issue and the mower is still doing the same thing. It will not run unless the choke is on and it sounds like it is running weirdly
   / John Deere 185 running issues #13
Still sounds like a carb problem. Take it off and completely dissemble it. Make sure you take notes and photos of it as you dissemble it. Thoroughly clean it using carb cleaner and then put it back to gether using new gaskets, and valve seats.
Richard
That was my initial thought on what the problem was and I did that, mind you this problem started when I pulled the head off and put it back on
At this point i will take any suggestions to what it could be because if i need to replace something i want to make sure that is the problem
   / John Deere 185 running issues #16
You sure picked a bear of a engine to work on. The valve spec for your engine is .06 not .05. That could make a difference if not adjusted correctly.
Valve adjustment specs.
Kawasaki Small Engine Intake and Exhaust Valve Clearances
Discussion on adjusting the valves.
https://www.mytractorforum.com/12-john-deere-forum/155013-easy-check-adjust-valve-clearance.html
The Kawasaki Workshop Manual for your engine link has stopped working......................
https://mymowerparts.com/pdf/Kawasa...20V-FC540V-KAWASAKI-SERVICE-REPAIR-MANUAL.pdf
   / John Deere 185 running issues #17
Luke ...... You said you cleaned the carb.....If you have the Nikki 2 BBL on your engine then something didn't go back together right..... Lots of parts on those carbs......
If you are still here I can shoot you a link for the service manual on the engine .....
Plus Tard Mon Ami ~!~!
that would be awesome thank you.
Some more info on what’s going on. I checked the valves again, they are set right and i know the engine was at TDC. When i start it on choke it starts up but when i back off choke the engine shuts down hard, like i turned the key off with it running at high rpms, that sort of sound.
   / John Deere 185 running issues #20
Richard
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2016 BMW X5 SUV (A50324)
2016 BMW X5 SUV...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
