John Deere 180 M00180B606226 basket case tractor
   / John Deere 180 M00180B606226 basket case tractor #1
mcfarmall
Veteran Member
Kalamazoo, MI
Kubota M5660, Farmall C, JD 260 lawn tractor
From tractordata.com is appears to be a 1989 model year I believe.
Son brought this thing home so I started playing with it. Mice had made a huge nest in the shroud but didn't compromise any wiring. PTO switch is missing. Engine is free and I can spin it electrically with a set of jumper cables across the solenoid. Gear transmission is free and brake is functional.
Haven't tried it with the keyswitch due to the missing PTO switch as my JD 260 won't crank if the PTO switch is in the on position. I need to figure out which wires have to be connected or whatever to simulate the PTO switch in the off position. Just a side note for the safety conscious, I'm ok with jumpering out the interlock for the PTO switch at least during the testing phase of my work.
Looking for advice on how to get the cranking circuit and the ignition circuit live so I can attempt to start the engine and determine if this thing is worth going further. I presume that the ignition circuit would go live in the start and run positions of the keyswitch.
Anybody out there have one of these and are they a decent, basic riding mower? Construction seems to be quite robust and typical old-school JD.
   / John Deere 180 M00180B606226 basket case tractor #2
1989 Model With 46" Mower and Engine (Serial.No. M00180B605001-750000)
B-Configuration Code (180 W/46" Mower)
I have a PDF of the tech manual with all the wiring in it, shoot me your email if wanted
Joe
Got the PDF successfully...thanks a bunch joecdeere! Got it to crank with the key and no spark. Using the troubleshooting/testing guide, looks like the ignitor is the first place to start.
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2006 HAMM 3205 SMOOTH DRUM ROLLER (A51246)
2006 HAMM 3205...
Kubota BX2230D (A47384)
Kubota BX2230D...
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
