John deere 175 lawn mower brake pedal doesn't release
   / John deere 175 lawn mower brake pedal doesn't release #1
des53952
Oxford, wi
John deere 175 hydro
Just purchased a used J/D 175 Hydro lawn mower. The brake pedal won't release after start up so I can't get full response from hydro drive forward or reverse. Any suggestions on cause and cure. This is my first rider mower, first J/D, first hydro so not familiar how whole system works.
   / John deere 175 lawn mower brake pedal doesn't release #2
:welcome: I would look for a return spring, mine broke a while back. Did the mower ever move? It could be rusted stuck if it's been sitting outside all winter... those are my thoughts without any further information.
   / John deere 175 lawn mower brake pedal doesn't release #3
I agree
Thanks for the info guys. I will start by looking at the spring. The tractor does move, but slowly without putting extra constant pressure on the forward/reverse hydro lever. I did get it to release a few times and everything worked great just as it should. I had to step down really hard on the pedal to get it loose. After turning the engine off, you have to push the pedal down to to restart and the pedal sticks down again. Other than the one problem stated, the tractor starts, runs and mows great. Not bad for 20+ years old.
   / John deere 175 lawn mower brake pedal doesn't release #5
may want to spray lube all the linkage pivot points too.
Cleaned up years of mowing crud & neglect and lube everything I could see that moves. All works great just like it should. Thanks for all the tips.
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2020 KUBOTA RTV...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A49461)
2019 Fontaine...
