John deere 175 lawn mower brake pedal doesn't release
   / John deere 175 lawn mower brake pedal doesn't release #1
des53952
Oxford, wi
John deere 175 hydro
Just purchased a used J/D 175 Hydro lawn mower. The brake pedal won't release after start up so I can't get full response from hydro drive forward or reverse. Any suggestions on cause and cure. This is my first rider mower, first J/D, first hydro so not familiar how whole system works.
   / John deere 175 lawn mower brake pedal doesn't release #2
:welcome: I would look for a return spring, mine broke a while back. Did the mower ever move? It could be rusted stuck if it's been sitting outside all winter... those are my thoughts without any further information.
   / John deere 175 lawn mower brake pedal doesn't release #3
I agree
Thanks for the info guys. I will start by looking at the spring. The tractor does move, but slowly without putting extra constant pressure on the forward/reverse hydro lever. I did get it to release a few times and everything worked great just as it should. I had to step down really hard on the pedal to get it loose. After turning the engine off, you have to push the pedal down to to restart and the pedal sticks down again. Other than the one problem stated, the tractor starts, runs and mows great. Not bad for 20+ years old.
   / John deere 175 lawn mower brake pedal doesn't release #5
may want to spray lube all the linkage pivot points too.
Cleaned up years of mowing crud & neglect and lube everything I could see that moves. All works great just like it should. Thanks for all the tips.
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52128)
John Deere 700...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2006 Volvo VNL (A52128)
2006 Volvo VNL...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
