John Deere 170 fuel problem
/ John Deere 170 fuel problem #1
geckman2
springfield, Missouri
John Deere 170
I have a John Deere 170 and it will run for about 10 minutes and then will die. If i disengage the blades sometimes it will continue to run but once I re-engage the blades it starts to die. If I let it set overnight it will again run okay for about ten minutes but then die again. It seems like it only occurs once the engine warms up. I have replaced the fuel pump and the filter but still does the same thing. I rigged up a fuel tank that is above the carbuerator (gravity flow) and it works fine for as long as I want to mow. Could it be a leak in one of the fuel lines or possibly the vacuum line from the engine block that works the fuel pump?
/ John Deere 170 fuel problem #2
Sounds more like a ventilation problem in your fuel tank, causing a vacuum.
Ended up taking the fuel tank off and pulling the fuel pick-up tube out of the tank. The pick-up tube was partially blocked with what appeared to be pieces of rust. Blew it out and am now putting it back together. I will post once I get it running. My tank actually had a vent tube that keeps it from creating a vacuum. Not sure if it came from the factory that way. Thanks chiming in!!
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
4' Mower Blade (A62679)
4' Mower Blade...
Used 20' Container (A62679)
Used 20' Container...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A65563)
2016 Volvo VNL...
