John Deere 160
/ John Deere 160 #1
DeereFan89
Plattsburgh, NY
'84 JD160 Lawn Tractor, '98 CubCadet HDS2135, Still Collecting!
Hey guys!
Got a 1984 John Deere 160 riding mower, runs, starts and drives awesome!! However as soon as I switch on my PTO, it kills my mower within a matter of seconds... what could be causing this?? PTO switch works 100% as its brand new
/ John Deere 160 #2
Have you checked the dead man switch in the seat? It sounds like it is acting like you are not sitting in the seat when you flip the switch.
/ John Deere 160
Looks like whoever repainted the tractor removed the switch & taped the wires together, my guess is they by passed the switch all together. Ordered a new one this morning.. when I install it, what if the symptoms are still existing?? What should I check from there?
/ John Deere 160 #4
If I were a betting man, I'd say that is your problem and a new part should fix the problem. I can't think of anything else that could be causing the problem. I worked on my 165 today and couldn't find anything else that might be causing the motor to shut down other than the deadman switch. Keep us posted.
/ John Deere 160
Did you pull your switch, Tape them together, and engage your PTO? Try that and let me know if your Engine stalls
/ John Deere 160
Its ALIVE!!! PTO is working 100% installed new seat switch works fine!! Only issue is when engaged the belts squeal like an sob!
/ John Deere 160 #7
Yea! Sounds like you have a running Deere again. I always turn the PTO on when the engine is at high idle and it squeals for just a few seconds. Now would be a good time to make sure the bearings on the mower deck are greased. I just removed and sharpened the blades, cleaned up the underside of my deck, painted it and greased everything and its running like a brand new machine. I have to admit though, it is such a pain in the butt to install the mower deck on the older Deere units. The snow blade goes on quick, but I hate it when spring comes around when its time for the deck to go on. I make sure I go over the deck real good before I have to go through the install process. If I end up with a squeal, I'll get out the WD40.
HONDA Plate Compactor (A64553)
HONDA Plate...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
PALLET OF CUT-OFF VALVES (A67714)
PALLET OF CUT-OFF...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
Unused 2026 CID SNLB84-S 84in. Snow/Ice Skid Steer Bucket Attachment (A66734)
Unused 2026 CID...
CRATE OF FLANGES AN PIPING (A68842)
CRATE OF FLANGES...
