John Deere 1470 Discbine reviews?
   / John Deere 1470 Discbine reviews? #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello, I'm looking at a 12' 1470 Discbine and am wandering if anyone has any options or want to give me their review of it.
Thank you.
   / John Deere 1470 Discbine reviews? #2
In their day they were a good machine. I believe that model used a Kuhn disc bar but I could be wrong on that. I'm not sure when Deere started making their own.
I know a few people that had them and liked them. Now one issue I believe that is also a bear to repair. Seems when something did break with the disc bar the whole unit had to be pulled and taken apart and even back 20 years ago it was 5-6K for repairs.
That's good to hear, the dealer said it could use new discs but said the ones on there will still cut.
Is it easy to repair for someone who is mechanically inclined?
   / John Deere 1470 Discbine reviews? #4
It's more about the newer cutter bars are built in sections and the disks are made to break and save the cutter bar. The older ones were more of a one piece design and if something broke it was usually inside the gear case and would damage the whole unit. I know a few guys that had them back in the early 1990's and like the newer ones much better.
If this link works you can see the cutter bar here.
John Deere - Parts Catalog
This here is a 920 cutter bar which is built in sections. Much easier to repair and possibly much less damage will be done if you hit a hard object.
Now with both if a gear breaks it's going to probably damage the whole unit, but a newer one will still be easier to repair.
Both can be fixed, its just a lot easier to repair a newer than an older.
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2014 International Bucket (A55973)
2014 International...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
