John Deere 111H fuel pump hoses
/ John Deere 111H fuel pump hoses #1
JD Tractor Novice
High Point, NC
1985 John Deere 111H
Hi everyone:
We were gifted a 1985 John Deere 111H (hydrostatic) lawn tractor. I've found a diagram that shows the vacuum line and 2 hoses leaving the fuel pump, but we don't where each of them goes to, where they terminate. Can someone please help?
Thanks a ton!
/ John Deere 111H fuel pump hoses #2
pretty simple really, one is fuel inlet from tank, one is fuel out to carb, the vacuum line goes to a port on the block
Fabulous! Thanks. Just one other detail: does the fuel line from the tank go to the bottom right port on the fuel pump?
/ John Deere 111H fuel pump hoses #4
There should be one port that is connected to the center of the pump. That is the vacuum port. hook up the line from the tank to one of the other ports, crank over, if if pumps fuel, then hook up other line, if not
reverse the hose to the other port. and try again
/ John Deere 111H fuel pump hoses #5
If you are looking at above picture, the inlet from the tank would be on the right top, vacuum, then outlet to carb.
Sox3:
Our fuel pump doesn't look like the photo you sent. A snapshot of ours is included here. After looking at this your insight would be most helpful. Thanks.photo.JPG
/ John Deere 111H fuel pump hoses #7
I cant tell much from that pic. You have the hoses hooked up to it so is it not working? have you tried it the way they are hooked up?
Engine model #s would be a help.
Sure, and before I forget it, thanks for your help. I am attaching more photos for you to see the piece we mean. And here are the details about the tractor and engine: John Deere C111H ID#222862; Engine model 284707, type 1026-E1, Briggs & Straton 12.0 HP.
/ John Deere 111H fuel pump hoses #9
if memory serves me correct, the fuel inlet is at top, the vacuum is pointing down out the bottom, the othe toward carb is out to carb. lke i said eariler, hook up vacuum and inlet, crank over and see if pumping fuel (into can or jar).
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2013 HYUNDAI HL770-9A WHEEL LOADER (A65053)
2013 HYUNDAI...
Kubota SVL75-2 Compact Track Loader Skid Steer (A64553)
Kubota SVL75-2...
2014 Ford Explorer AWD SUV (A64557)
2014 Ford Explorer...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
