John Deere 110TLB 2007
   / John Deere 110TLB 2007 #1
fireout66
Nazareth Pa
John Deere 110 TLB 2007 , Bobcat 763 skid loader
I have a 110 tlb Mfg 2007 with 610 hrs. I bought this machine used it was not commercially used. It was used on an estate and has not been used for the last year. I have fwd / rev issues just after it starts to get warm approx. 5-10 min. run time. All loader and hoe functions are ok it just stops and will not move after shutting off and waiting several minutes it will move but continues to do same thing. This started in early march at about 10 deg. temp. I did not use again until now at 70deg same issue. Where do I start ? There is a code flashing on the screen.
   / John Deere 110TLB 2007 #2
Why don't you let everyone what the code # is?
I am not positive of the flashes and sequence. I do have the owners manual with the code guide. My problem is right now I am in PA and the machine is 5 hrs away in NY. I am going to change the filters and hydraulic fluid to start end of week.
   / John Deere 110TLB 2007 #4
I have fwd / rev issues...
Could you be a little more specific on what you mean by issues, does is not move at all, does it move slowly, does it buck/jerk????
changing the fluid& filters would eliminate that as the cause; although I honestly doubt that would be it, but if you are due/overdue for a change, than have at it.
I understand you can not get the code right now, but that would really be helpful for those trying to help you.
Also be aware that a flywheel speed sensor (less than 100$ and very easy to change) is known to cause issues. there are several, if not many posts about that...
keep us updated.... best of luck
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
