John Deere 110 Won't Move
   / John Deere 110 Won't Move
I think I found the picture in the JD parts manual online. It appears that there is a roll pin inside (#4) that connects the shaft (#9) to the range shifting components. Does anyone have experience dealing with something like this?
   / John Deere 110 Won't Move #12
I found my problem. My forward pedal was not coming all the way up. This caused the controller to think I was pushing down both pedals. I oiled the linkage. No more problems.
   / John Deere 110 Won't Move #13
Way to go!!!
Really appreciate you posting because we 110 owners need this kind of information to keep our tractors working.
Here's the final outcome of my problem that started this thread. It was the roll pin #4 in the previously attached drawing that was sheared off, inside the case. There was about 1/2" of this pin remaining. It was a 74 cent part but took a lot of time to get to. I removed the left fender, the seat, the plastic cover and then the RockShaft cover and it was right there. If this happens to anyone make sure you get the right pin. It's an oddball metric size. There are versions that are close at Ace hardware but I decided it wasn't worth tearing into again to replace the wrong pin. I also got new filters, new oil, and new sensors along the way but they probably needed replacement too.
A great big thanks to the Guys at RDO Equipment in Phoenix. I know it's not a big deal but they gave me that pin, free of charge. That's the little stuff that means a lot to me......just like all of you sharing your wisdom. Thanks again to everyone and happy digging!
   / John Deere 110 Won't Move #15
Great Detective work and thanks for sharing what you found.
What exactly does this shaft operate?
   / John Deere 110 Won't Move #16
Thanks for the info AZOutlaw...I have the same issue. I had hoped it was the external roll pin fastening the gear selector lever to the transmission shaft but no such luck. I have the machine stripped naked waiting for a full day of sun before I attempt to remove the rock shaft assembly from the top of the transmission. If I can remember where all the screws go by the time I put it all back together, I'll be a happy camper!
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
