John Deere 110 TLB surging
   / John Deere 110 TLB surging #1
Jbrink64
OK, I have a JD 110 TLB with a surging transmision. The "open book" light comes on momentarily when the key is turned on. It is not flashing any codes. The problem worsens as the machine warms up. The voltage to the HST sollenoids varies in rythem to the surging. Unplugging the engine speed sensor causes the light to flash a code for the sensor, and the transmission stops surging.
Anyone have a fix for this? Would recalibrating the trans help, and what is the procedure to do it?
Thanks.
   / John Deere 110 TLB surging #2
Well... it sounds like you've already isolated the problem! The engine speed sensor. Unplugged - code flashing - surging stops.
Replace the speed sensor.
I'll take a look at my Technical Repair Manual and see what information is available there. But, in the meantime...
How expensive is it to replace the speed sensor?
AKfish
I replaced the speed sensor, that didn't help.
   / John Deere 110 TLB surging #4
Does the engine rpms' surge while sitting still or does the tractor movement surge at a set rpm?
The engine will stay at a set speed. The ECU will rapidly change the voltage to the HST solenoids, causing the surging.
   / John Deere 110 TLB surging #6
I would have the dealer plug in to it and perform a diagnostics on the unit. When I first got my 4520 home the computer wouldn't allow the tractor to move. The dealer came out and reprogrammed it and no further problems in the last two years.
   / John Deere 110 TLB surging #7
Did you ever find the problem with the surging? I am having the same problem. Any help would be great.
Britt
Britt
The engine and ground speed sensors both failed, then the trans needed recalibration.
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
Informational Lot - Financing (A51039)
Informational Lot...
2002 International 9200i Truck (A51039)
2002 International...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
