John Deere 110 tlb loses oil pressure
   / John Deere 110 tlb loses oil pressure #1
gravedigger2
lapeer,michigan
john deere 110tlb,Ford 4500 tlb,Case 580L tlb
I have a 2011 JD 110 tlb it has a yanmar diesel I had a overheating problem that required the engine block to be machined and a shim put in between the block and head. All went back together good starts and runs good. The problem is it doesn't build good oil pressure only about 20 psi cold and after 10-15 minutes it loses oil pressure slowly. I was thinking it could be a bad or pinched oring in between the engine and the oil pump pressure side any suggestions would be appreciated. Planning on pulling it apart this weekend
   / John Deere 110 tlb loses oil pressure #2
Did you replace the main bearings when you got the block machined?
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
VARIETY BOX OF SCHUMACHER BATTERY CHARGERS (A51248)
VARIETY BOX OF...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
