Oil & Fuel john deere 110 1974 model
   / john deere 110 1974 model #1
vernonwright
I have a pretty good running tractor, except for a burning oil issue and the other one is restarting when hot. I think the problem is a low compression but I want to see what we all can come up with. Ok, so it uses a bit to much oil and I can see smoke as I cut. The second thing is when I shut it off hot it will not restart until 30-40 mins after it has cooled down. I have noticed a lower power at higher speeds. Am I on the right track?
   / john deere 110 1974 model #2
Sometimes hard re-starting when it's hot can be caused by a dirty air filter. Hot engines don't like to be choked. Probably not the problem in your case but it only takes a moment to check it. If the filter is clean, then you're probably on the right track. Some oil in the chamber tends to ****** normal combustion.
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
