jcp6649
Hi all, I recently purchased a used JD1050 and noticed that when I pull the PTO lever back to disengage, the shaft continues to turn ever so slowly. If I keep upward pressure on the lever, the pto will stop completely. If I let go of the lever, it slides forward a fraction of an inch.....just enough so that pto turns slowly. It doesn't seem to be affecting anything. The tractor runs and sounds great. Any ideas on what could be causing the handle to slide forward? Also, I noticed the tachometer doesn't seem to be working. The hours are incrementing correctly but the needle doesn't seem to want to move. Any ideas on getting the tachometer to respond? Any help is greatly appreciated!
-Jonathan
-Jonathan
