John Deere 1050 Electrical Issues
   / John Deere 1050 Electrical Issues #1
rangerman942
Poplar Bluff, MO
John Deere 1050
I am experiencing electrical problems with my JD 1050. A while back it blew the top off a new battery. I checked the voltage output at the battery and it was charging at 18 volts....too much. I took it to a repair shop for other issues and while it was there I had them check the alternator and it was working properly. So the assumption was the voltage regulator was bad. I purchased a voltage regulator online, note: my old was was a mechanical one, the replacement was a solid state. I have the tractor back now and it's not charging at all. I also notice my fuel gauge doesn't work and my 3 indicator lights won't power up. It starts and runs great until the battery dies and I have to charge it. Any suggestions on where to start trouble shooting. Alll wiring looks good and no shorts anywhere. I have taken off the alternator and voltage regulator and am having them tested on Monday. Hopefully that will tell me what issues I have with charging. Any ideas on the other electrical issues?
thanks in advance.
   / John Deere 1050 Electrical Issues #2
Welcome to TBN
Know how frustrating these problems are to sort out. Sometimes a pig-in-a-poke when ordering online, but then so can be going to a store and learn that being new doesn't mean it is going to work right.
Having a wiring diagram and just working your way along to locate a trouble spot is best I can recommend.
This site will be your best bet for help, and there is vast amount of info in TBN's past, but sometimes searching for it can be a feat by itself.
Seems to take a special skill to search here. But worth a try, IMO.
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
96in Large Capacity Bucket (A49251)
96in Large...
International 3pt Disc (A49251)
International 3pt...
Allis Chalmers D19 2WD Tractor (A49251)
Allis Chalmers D19...
Woods C-80 Pull Type Mower (A49251)
Woods C-80 Pull...
APV PS800 M1 Cover Crop Seeder (A49251)
APV PS800 M1 Cover...
