John Deere 1020 Replacing Oil Filter Threaded Nipple
   / John Deere 1020 Replacing Oil Filter Threaded Nipple #1
courter
Chicago
JD 1020
I have a John Deere 1020 tractor. The threaded nipple came out with my oil filter. It does not slide back in easily. Do I just hammer it in place and if so, do I line up the threaded nipple to be at the bottom where the oil hole is? Or do I turn it some degrees off so when it tightens it lines up?
   / John Deere 1020 Replacing Oil Filter Threaded Nipple #2
Welcome to TBN
JDparts.com shows the nipple but I have no idea how it attaches to block.
T23435 Threaded Nipple - THREADED NIPPLE,OIL FILTER ADD 31.83 USD
   / John Deere 1020 Replacing Oil Filter Threaded Nipple #3
G'day my guess is that it will thread back into the block , clean both the threads up and a drop of loctite should stop it from coming out again. As far as depth goes screw it in and see if it bottoms out if not screw it in and butt the filter up to the end of the thread you want about a 1/2 to 3/4" gap between the filter housing and the seal before you screw the filter on
Jon
Thanks for your input but only one side has threads. The side that goes into the tractor just slips in (tightly). I ended up buying a new part, cleaning everything with carburetor cleaner, using a high temperature loctite, and hammering the part in using a big socket to protect the threads that teh filter screws into and waiting overnight. So far so good.
Informational Lot - Shipping (A52128)
Informational Lot...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
