John Deer 47 Snowblower Application Question.
   / John Deer 47 Snowblower Application Question. #1
zzvyb6
Super Member
michigan
jd 1070
I have an older JD f-935 front mower that's used exclusively to mow the lawn. But, it starts easily in frigid weather and did have an optional attachment of a "47 2 Stage Snowblower" available.
There are a few used "47 Snowblowers" for sale in local want ads, but here is my dilemma:
Deere Parts website shows 3 versions of the 47 blower for my F-935:
1) A non-Quick Hitch bolt on version that plugs into the tractor's lift arms.
2) A Quick Hitch version with a CW blower fan (looking forward from the tractor).
3) A Quick Hitch version with a CCW fan.
Then there is the Auger drive arrangement:
1) Blower fan discharge offset to the right (CCW fan)
2) Blower fan discharge offset to the left (CW fan)
The fan directions are set by either a chain and sprocket transmission (fan same directions as input PTO)
or a reverser gearbox (fan opposite direction as the input PTO).
If any of you have an F-935, F-910, F-925 mower with the optional 47 2 stage snowblower, I'd like to know which fan direction and which PTO transmission mechanism you have (gearbox or chain and sprockets) .
My F-935 PTO rotation direction is CCW (looking forward). What I want to find out is whether the reverser gearbox can be replaced with the sprocket drive if the blower came off of a 318 or a 420 series tractor. The PTO rotation on those machines is CW so they USUALLY have a reverser gearbox (unless the fan direction is also CW).
I know this sounds complicated and a bit absurd, but I'd like to experiment with a blower. I already use an 8' tractor mounted blade to do my long driveway, but my 1070 don't even get warmed up during a moderate plowing job. So, I want to try the F-935. The number of permutations of the 47 blower model is boggling my retired mind.
Thanks for the help !
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2018 Chevrolet Traverse LT SUV (A50324)
2018 Chevrolet...
TAKEUCHI TL6R SKID STEER (A51246)
TAKEUCHI TL6R SKID...
