john deer 425
   / john deer 425 #1
wanna
orleans county new york state
jd 1070
hi guys i have a 425 jd with a54 inch mower when i engage the mower deck to mow the lawn the mower deck does not seem to spin up verry fast and when i try to mow it lugs down the engine allmost to stalling if i dont mow the motor seems to run fine i changed the air filter still no goood any ideas would be great as to what is wrong i also changed the tranny oil because it was low mabey it had 4 or65 quarts init when i changed it mabey the miotor spe3ed is wrong at full throutel not sure thanks art
   / john deer 425 #2
Check ur throttle. Make sure that when u got to mow, the throttle is near fast speed. Might also want to check your PTO and drive belts. The belts could be loose.
   / john deer 425 #3
Did you change the tranny filter? Does the tractor travel good up hills? What happens when you hold the hydraulic control arms all the way in one position? This will put a load on your tranny too, albeit less than engaging the deck. That transmission is pretty complicated. But, if everthing else is working, sorry to say, it sounds like it could be PTO clutch is going or engagement solenoid. The latter wouldn't be so bad. The former would be a lot bigger repair job.
I just did the cam gear replacement on mine. Not too bad. But, tearing into that tranny is a whole different animal.
   / john deer 425 #4
Make sure you check the oil in the gear box, for the deck. I had my start to do that and found the box almost empty. Found out that new gear boxes ain't that cheap.
   / john deer 425 #5
I don't Make sure you check the oil in the gear box, for the deck.
   / john deer 425 #6
Art, do yo think there's any chance
the motor is running 1 cylinder? or
missing on 1 cylinder? That motor
will run on one quite well, but not develop
the power it needs. you can pull spark plug
wires 1 at a time and see if it changes how
the engine runs. if you find that pulling 1 wire
doesn't change things, you may not have spark on
that side, which could be a bad plug or coilpack.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
WB Mower (A50120)
WB Mower (A50120)
UNUSED LANDHONOR LHR-SB2T3M CHAIN LEVER HOIST (A54757)
UNUSED LANDHONOR...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
Lincoln Electric 225 Ranger Welder Generator (A52377)
Lincoln Electric...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
