john deer 425 pto problem
   / john deer 425 pto problem #1
wanna
orleans county new york state
jd 1070
Hi guys i have a j.d. 425 when i engage the pto sw it blowes the 15 a fuse if i disconnect the pto selenoid at the rear of tractor all is good could it be a bad solenoid i rang out the wiers to check for a grouned wier this was allso ok ohmed out the solenoid it self and have 0.0 ohms acrossed it not sure what it should be thanks for any info Art
   / john deer 425 pto problem #2
Art,
While they are different tractors, I had a similar problem with my 332. I removed the rear PTO and disassembled it, and found out that the clutch was way out of adjustment. The field coil was actually rubbing and had bare wires on the surface of the coil. It would work sometimes and generally short out after it warmed up. So you could get good measurements on it even if the coil is damaged. I'd suggest taking it apart and looking around.
   / john deer 425 pto problem #3
A zero ohm reading is telling you you've got a direct short, which as you know, pops fuses.
I see a new solenoid in your future.
   / john deer 425 pto problem #4
The 425 has a plug for the optional rear pto that lays inside the bottom of the frame rail. I forget which side. Check to see if it is hanging down and rubbing on your drive shaft and shorting out. There should be a couple rosebuds that hold it in place out of the way. Mine popped out and allowed the wire to rub on the shaft.
It is a 2 wire plug, T shaped from the end I think.
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2008 Ford Ambulance (A47477)
2008 Ford...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2014 Ford F-150...
2012 KENWORTH T8 DAY CAB (A54607)
2012 KENWORTH T8...
70pc 8ft.x 3ft. Grey Metal Roof Panels (A55758)
70pc 8ft.x 3ft...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
