JM 454 Hi speeds problems
/ JM 454 Hi speeds problems #1
gree
Hello I have a Jinma 454. I have the following problem with this: when I move to speed Hi, it does not take speed? Revolutionizing the engine over 2000 rpm without problems. In the low 1,2,3 I have no problem, the power seems to be correct. The problem is it in the clutch ... Thank you
/ JM 454 Hi speeds problems #2
No, more likely in the Hi/Lo selector lever. Between the Lo and the Hi positions, is a psuedo neutral. I suspect the throw on the lever is not making it as far as Hi. When in the psuedo-neutral, the gears are simply not engaged.
Check the bottom of the select lever for a broken roll pin
//greg//
2018 MACK PINNACLE (A60736)
2018 MACK PINNACLE...
2024 JCB 35Z (A60462)
John Deere 1023E (A62177)
John Deere 1023E...
2012 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2012 Chevrolet...
TAG 18in Digging Tooth Bucket Excavator Attachment (A60352)
TAG 18in Digging...
2022 Horizon Trailer (A55973)
2022 Horizon...
