JM 335 Duel Clutch major problem
   / JM 335 Duel Clutch major problem #1
MikeLonghurst
I live in France and have had my Shire 335 (35HP re-badged Jinma) for just over 12 months now. After having done 55hrs I was aksed if the farmer next door could borrow it to do some work in his barn and the Jinma was smaller and able to manouver a lot better. Anyway 3 weeks later he returned the tractor and it now had 117hrs on the dial and also a loud sound when the clutch was depressed. Took it down to the local tractor garage and they split the beast. Went down yesterday to see the damage and they said that I need the following replacement parts: 1 x Throw out bearing, 1 x PTO clutch driven plate assy, 3 x sub release levers, 2 x disk springs.
The mechanic said that he thought that the Throw Out Bearing Seat had stuck and that this had caused excessive wear and overheating of the various parts. The ends of the Sub Release Leavers were totaly worn away. As they normaly deal with MF and other major brands, he could not fugure out how the Throw Out Bearing Seat was meant to be lubricated and sated that he considered this to be a major design fault.
Has anyone any ideas how the Throw Out Bearing Seat is lubricated? Also anyone any idea as to why this type of damage would have occured. The farmer next door was mainly using the tractor to run a PTO driven generator (with tractor engin running at max speed).
Any advice appreciated as the repair bill for this looks like comming to about £1,000 and the French Farmer is likely to say that if this is a design fault he should be responsible!!!
Rgds, Mike L
   / JM 335 Duel Clutch major problem #2
I can't speak for the bearing lube, as my KAMA has a grease point. But the photo of the release levers suggests that that problem was in the clutch linkage adjustment, rather than a lubrication problem. The release fingers are not supposed to contact the throwout bearing when the clutch pedal is fully released. Yours were obviously making (quite excessive) full-time contact. I believe a gap between 0.1mm and 2.0 mm is specified.
This is an adjustment that should be performed by the selling dealer, hence a warranty issue. If you put it together yourself.....
//greg//
   / JM 335 Duel Clutch major problem #3
I think it was Ben Franklin, who had a high regard for the French by the way, that said "neither a borrower or lender be" but that won't help now I suppose...
When we have seen this type of failure, it has been from failure to maintain 1" of pedal free travel on the clutch. the throw out bearing is not designed to be in constant contact wiht the fingers on the clutch, the bearing will overheat, sieze and burn the tips of the fingers off, just as your photos show. this can also be done by resting your foot on the clutch pedal during operation. The fit between the bearing seat and the support is very loose, I thik it would be hard to get it to seize and if it did, it would seem you would tell by clutch pedal not returning to normal position.
   / JM 335 Duel Clutch major problem #4
That clutch/throwout design is not much different than that used in many forign automobiles. I know Toyota has used something similar throughout the 80's and the only real difference is the use of a hydraulic slave cylinder to actuate it and more fingers/levers on the pressure plate. They probably still use something similar but I havn't cracked a toyota any newer than an 88.
The Bearing is pressed onto a carrier assembly. This assembly slides on a tube(moved by a fork) through which the transmission input shaft passes. That assembly and tube is greased upon installation, or any time the unit is broken down for clutch or bearing repair/replacement. there is no grease fitting on them for routing maintenance. If greased properly at install, these things should operate fine for a long long time. The toys and nissan/datsuns I have worked on have never had any problems between required clutch disk replacements. Was there grease on the inside of the bearing carrier and the tube it slides upon?
As mentioned, the bearing carrier should fully retract so the fingers/levers on the pressure plate do not touch the bearing. In this case that is accomplished by the return spring on the clutch pedal.
My vote would be either a mis-adjustment, in which case it would have happened to you eventually. Or something inadvertantly set/fell against the pedal taking up the freeplay/gap between fingers and bearing while it was being used as a generator, Or somebody riding the clutch pedal/slipping the clutch, instead of selecting a slower gear...
What did the wear on the clutch disks look like? If they are really burnt up with only a hundred+ hours, that might lead me more in the direction of operator error.
Good neighbors can be hard to find... I would hope that your neighbor would feel bad enough about it breaking while he was using it, even if it wasn't his fault, to at least help out with the repair bill.
Good luck
   / JM 335 Duel Clutch major problem #5
<font color="blue"> I live in France and have had my Shire 335 (35HP re-badged Jinma) for just over 12 months now. After having done 55hrs I was aksed if the farmer next door could borrow it to do some work in his barn and the Jinma was smaller and able to manouver a lot better. Anyway 3 weeks later he returned the tractor and it now had 117hrs on the dial and also a loud sound when the clutch was depressed. Took it down to the local tractor garage and they split the beast. Went down yesterday to see the damage and they said that I need the following replacement parts: 1 x Throw out bearing, 1 x PTO clutch driven plate assy, 3 x sub release levers, 2 x disk springs.
</font>
Hey Mike,
We all want to be good neighbors, and want to help our neighbors out. My Dad was a farmer, and exchanged equipment with other farmers, when the situation's arose, in order to try hold equipment costs down, etc. The agreement was always, to return the equipment in the same condition. The exception was normal wear and tear.
However, a lot of the times, he got his equipment back and something was broken. And he told me not to do it, as it is a money losing proposition.
Your neighbor should bear the cost of fixing your tractor, period. However, most likely he will balk and make up several excuses, to avoid this, as he was in the beginning trying to save money, by borrowing, someone elses equipment, and this will cost him more money.
Your neighbor assumed the risk, when he borrowed your equipment, and should do the right thing, and pay for the damages.
Unfortunately also, you as the lender also assumed the same risk, in that, if the equipment is broken by the borrower, that they will not be willing to repair the equipment. /forums/images/graemlins/frown.gif
A true "Good Neighbor", would have told you of the damage, assumed the risk, and would have asked you to which repair facility, that you would like for him to take it to for repair.
Now, I could see maybe if Lightning or a Flood had damaged your tractor, but this was damage done while the tractor was in operation.
He used your tractor for 62 hours, so that also has a monetary value as well, that could be figured in more ways than one.
Hope everything works out, and you and your neighbor still remain good neighbors.
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / JM 335 Duel Clutch major problem #6
The three week part bothers me some, do you think he would have ever brought it back if it hadn't broken? He owes for the repair in my opinion. I only have 140 hours on mine in 14 months.
   / JM 335 Duel Clutch major problem #7
The throw out bearing is not lubricated it only turns when you depress the clutch, what happens most of the time is the clutch was out of adjustment from day one so the throw out bearing has been turning the whole time the tractor was running.which has caused some heat damage and wore off the release fingers. Do you have a source for the clutch assembly, we have all the parts in stock to replace this, send me a PM and I will get you more information. Also do you have the manuals for the tractor?? we can help you with them also
Tommy
Affordable Tractor Sales web page
Hi there and thanks ever so much for the replies, they have been very useful. One thing that occurred to me is that the PTO Clutch pressure plate was badly heat scared (picture attached) and the PTO Clutch driven plate assy needs replacing. I am not a technical or mechanical guy at all (god how I wish I was) but wondered, if the guy linked up a heavy generator (which he did for a few days to power grinders etc) to the PTO and ran this for a number of days. Would this cause the damage to the PTO plates? (i.e could the generator have been to much for a 35HP tractor).
Could anyone advise how long it should take to rebuild the tractor once the French mechanic has the new clutch parts? He has said it should take about 2 days!!! Not sure if this sounds right.
The French Farmer by the way has about 6 big tractors which he uses on his farm. He asked to use mine because it could get into the small places. I was quite surprised when I saw him using it for running the generator but thought nothing of it at the time.
The thing should be able to be resolved amicably as the farmer owns the large cattle building very close to us and we supply all his water and electricity (he owns the adjacent land but actually lives about 20 miles away and we have the only water and electricity supply in the area – he also uses our electricity to power his fencing for all his cattle). If there is a problem with him agreeing to pay for the repairs to the tractor I would simply explain that I had been neighbourly and trusting and as he has abused this trust I will simply switch off the water and electricity supply (all located in our cellar). This is not something that we would want to do but I would be prepared to do if the situation is not resolved amicably. Also this being France, if word got out (and like rural communities all over the world word spreads fast) that he broke our tractor and left us in the lurch, his name would become mud round here and the entire community would turn against him quite quickly. Even though we are Brits in France we are part of a small community of only 185 people here and they really do support their own (even if we do overcook our food!!!).
Tommy. I may be in contact with you shortly. Want to see what the dealer in the UK says first about sending parts out here. Don’t have much faith in this happening because the tractor arrived late and the attachments came out 2 months after the promised delivery date. Also had no manuals or anything with the tractor. The French mechanic at the garage is working from a picture of the Duel Stage clutch that I got from the internet..that is all he has.
Regards, Mike L
I have attached a picture of the PTO Clutch Driven Plate Assy which the mechanic said needs replacing. The other side is as pitted and marked as this picture. It looks pretty badly marked but not sure what thickness it should be in good condition.
Rgds, Mike L
   / JM 335 Duel Clutch major problem #10
That looks like a pic of the main disc,not the pto,but it does not matter as it will have to be rebuilt at this point, our assembly will have the new clutch,pressure plate,pto disc.We also have the throw out bearings and a complete set of manuals.Let us know if we can help,shipping cost would be high unless you wanted to wait on the slow boat from China.
Air freight you should get in about 3-4 days
Tommy
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2014 Mercedes-Benz Sprinter 2500 Ambulance (A51692)
2014 Mercedes-Benz...
2019 John Deere 5075E (A50123)
2019 John Deere...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
