JLG T350 Lift
   / JLG T350 Lift #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Bought one of these last summer. Great machine for what I do.
I removed the batteries (4 six volt) from the machine to keep them on a battery tender in the garage all winter. Now I can't remember which cables go where.
There are two long leads on each side of the machine from inside. Both cables on one side say "Battery - left side". So I attached both to the negative terminals on the left side batteries. Then there is a short cable that I attached between the positives on those batteries.
On the other side of the machine there are two cables labeled "Battery + right side". I attached them both to the positive terminals. Then I used the supplied short cable to attach the negatives on those 2 batteries.
No go. No power to anything. Batteries are fully charged and terminals are clean. If I plug the internal charger in, it goes through its red/green/yellow light test sequence and then the red light constantly gives 2 flashes. That indicates low voltage according to the manual.
Does anyone know what I've got goofed up or have a diagram of how these 4 batteries are hooked up? I came up with a manual here, but it only mentions battery maintenance and terminal cleaning.
I guess this knucklehead should have marked things before removal!
   / JLG T350 Lift #2
   / JLG T350 Lift
Scooted up to a local rental place where a friend works. They've got 2 of the same model so I went up and made a diagram. Heading out to the garage now to see what I've got.
   / JLG T350 Lift
The 15 minute ride up to look at other T350s was worth it. Batteries back in, hooked up correctly and lift operational.
Haste is not your friend. :confused2:
ABI TR3 LOT NUMBER 147 (A53084)
ABI TR3 LOT NUMBER...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
